- Feb 9, 2017
- 5,253
It’s best to really tighten that feed t nut as tight as possible. I’m not sure but I think that’s one of the leading causes of ratchet box crashes. And believe me you DON’T want that to happen.
For me the cutter head it too high. I shoot for the dovetails being fully engaged and work down from there. I also put a couple of quick lock handles on the head to lock and unlock the head gibs. This vastly improved my accuracy as it will want to pull the head down or push it up if you have any lash in the feed screw like I do. It’s on the list to be replaced along with the table feed.
