- May 4, 2019
- 792
Those are NOT industry standard inserts. You may be able to buy 13mm square bits with brazed inserts. You would have to sharpen the inserts and machine the sots for the 6mm screws. It is not a worthwhile project because you would still have a poc cutter.
Note: Import bits with brazed carbide almost always need to be sharpened to create the correct clearance angles.
