- Sep 24, 2020
- 1,911
Taps go in a tap wrench, either style.Yep - I knew I could rely on you guys!
Given the subject title of this thread, it is going to get searched and lurked by beginners, and there is already a ton of good stuff.
My thanks to @Lo-Fi for the UK links.
@Jim F answers the question about what a chuck is used for.
So my My Mill Rules #1 is - Chucks are only ever used for holding drill bits.
This naturally leads to the #1 consequentials. Cutters go in collets, or tapers. Taps also.
I am bound to discover more no-no's.
Just for information, I spotter a batch of cutters going cheap in eBay auction. Maybe the reason is the threaded ends.
Only now that my attention is on cutters, I see it, but I never noticed it before. Is this a "standard" or common thing? Would cutters like that still be usable in a collet? That would look a bit short, but what do I know? FYI - I passed on those.
My Mill Rule #2. Pay attention to collets!
I am going to go with the advice from @DavidR8 that ER32 is a OK collet size range to work in a MT3
The #10 post from @markba633csi suggests that 1/4" or 3/8" endmills are a suitable size. So 6mm to 10mm.
I looked at charts on --> This handy page --> https://littlemachineshop.com/info/er_collet_sizes.php
ER32 can do 1mm to 20mm, and is, I suppose, about the largest that can fit up a Morse Taper MT3
I know one can splurge on a whole set, or take the approach of building up a set, buying the size as the need arises.
Here we are going to run into "which collets"? Chinese or not? Can they be crap? What about the MT3 collet chuck? What are the warning signs? I suppose if the deal looks too good to be true, it probably is.
Given the South Bends have MT3 spindle as well, the collet set can be used there also.
The vise.
As important as the collets. Pretty much you don't do anything without it. I might go for something like @Lo-Fi suggests.
Parallels?
Sure, we can make them. The thing is, ground bar is already super accurate. It looks as if one can simply cut up some hardenable bar, finish the ends, and heat them up some with a plumbing torch.
Just for some orientation. Consider (say) a first collet set of 6 covering from about 3/16" to 3/4" plus collet chuck. (about 4.5mm to 20mm).
For reasonable quality, would $120 to $150 be enough? (about £90 to £113)
Thanks for @AmericanMachinist providing the link to Abom79. Oodles of stuff there. I do consider YT as my greatest education tool, but I also know that there are not enough hours in my life to watch even the stuff in my line of interest. Links from HM members help zero in on stuff they already filtered.
Thanks @Mitch Alsup as well. 4 flutes for steel. 2 flutes for aluminium!
I have quite a lot to absorb here. I will post questions/stumbles as they arise.
One thing that is not up to the job is the re-purposed COVID-19 plastic face shield. I take it that without protection, hot chips will make it into the eyes !
Those endmills with threads will work, they are from a co. over that makes a holder for them, but is not require.
As a side note, I have 3, 1/4" versions of those endmills.
Threaded endmills ?
These came in a box of end mills from an estate sale. Anyone ever see these? I can make out "Clarkson", 1/4 and England on the shanks.
www.hobby-machinist.com
