- May 27, 2016
- 3,479
After the unabashed urgings of the HM rabbit hole squad, and wanting to get ahead of possible future import charges and general financial mayhem, I did purchase a little mill-drill machine. --> Thread HERE
It has not even arrived yet, but now I have to get together at least enough to cut the first test chips.
The T-Slots are 10mm. They are the sort of thing one can make, but I got a few 10mm T's with 8mm threads from eBay to get started with.
What about a drawbar? I have no idea whether the mill comes with one. I tried the HM search. maybe I can make one. I take it that trying to mill with a MT3 taper mounted tool, and no drawbar, can be a recipe for injury and broken stuff?
The spindle has taper MT3. I guess getting a first milling cutter is next - but which one? HSS or carbide? How many flutes?
Should it be 2 cutters minimum? End mill + something else. Should it include fly cutter?
Humdrum stuff. I suppose some kind of clamp-down things. What is best here?
Duh! Parallels! Can I cut up some ground stock? How to harden it? Maybe just throw them into the woodburner/
A milling vise of some sort. Split type? Tilty over up to 45° type?
Can one do milling OK without a cooling pump kit?
A wobbly edge finder?
Oh yeah - what about DRO?
I only ever messed with a lathe, and that not much. Now I have the South Bends, albeit one in pieces
Am..mm I sh.. sh..showing s-s-signs of n-n-n-new aaaaaa-d d d dictions already? (Twitch)?
