- Dec 6, 2015
- 813
Here's some pictures of the needed gear. The gear has the same dimensions as the gear that is on the spindle right now, except that it is 2.000" long (not a critical dim). In trade for these pics, I need a picture from you - I want you to take a picture of the insides of both the yoke segments (the two bronze pieces under the handle - loosen the set screws on the handle and they will just fall out).
Also, one more thing... The gears are made out of CAST IRON, so DO NOT try to pry them off with a screwdriver. ONLY use a gear puller to remove them. The TAKE UP NUT right before the gear on the spindle is ALSO CAST IRON! To remove the gear may involve REMOVING THE ENTIRE SPINDLE in order to get enough room to place a gear puller behind the gear. The gear is a loose press fit and MUST have the woodruff key in place. Hitting the location of the key from over an inch away can be daunting, so if you miss it, pull the gear again and try again. Do NOT try to spin the gear on the spindle to hit the key - this runs the risk of cracking the gear.
View attachment 299195View attachment 299196View attachment 299197
SLK001, can I ask a favor? Do you have measurements for the gear? Inner diameter I can easily get, and I believe the over all length is 2". I'm wondering about the outside diameter of the flange. Is the long gear also cast iron?
silverhawk
