- Apr 23, 2023
- 36
I have been slowly progressing on the ELS for my PM 1030. I am doing too many other things.
I have all the parts (I think), everything programmed (I think), an enclosure for the electronics. I cut a hole for a fan, then many small holes for the intake. This box had a removable panel on the bottom, so I 3D printed up a plate that fits with 4 holes to accept the pin connectors I’m using.
I printed a holder for the Ti electronics, some holdowns for the 12V power supply. Power supply is mounted, 12V supply (for fan) mounted, fan mounted, intake filter. I got too small a box for the 110 outlet I have for the 5V and 12V supplies. Just need to pick full size one up and mount on the backplate.
I’ve been wiring up everything in the box, those are all done. Next I have the cable for the integrated servo soldered to the pin connector. I need to measure how long to make it, then do the encoder to pin connector. Same with servo DC power and display.
Once I have all wired up, I will test on the bench and make sure everything really works. Then mount the servo in the ’body’ of the lathe with some mounts I printed up. Take off the original gear on the spindle and mount the toothed belt one. Mount up encoder with mounts I printed up, then install new toothed belt gears and see if it works.
I hope to have a list of everything I used and can share the Fusion 360 files and STL files for anyone wanting to print up what I did (or I can print them). I have gotten a lot of help here so would like to help any others wanting to do it. (But better wait to make sure I did everything right!)
