- Jun 12, 2014
- 4,822
Each company carries a range of machines over a wide price range. I looked at some of the other Acra mills (and also Kent, Gizzly, etc.) when I purchased my LMV mill and many of the less expensive models were dated design and not as well built. A lot of the Kent models at the time had been around for a decades, they recently redesigned their mills. Grizzly's SB line is their high quality line, many of their bigger lathes (1330 and larger) sold are made by Sunmaster. I would not draw conclusions about a brand/distributor based on a single machine they carry. Warranty and service wise, from my experience (direct and through working with others) with multiple machine distributors I would rate QMT/PM at the top of the heap. The Sunmaster manual lathe line (ERL, RML, TRL) is a much heavier duty and higher quality line then the 1340/1440GT and the Eisen 1440E/GE/EV, they are also more expensive. The Acra LMV/Sharp LCM has been in production for many years, and I compared it to several other mills and it is a much better built machine. Still the design's for manual mills are archaic. With the advent of CNC machines, there is little incentive for manufactures to invest in a major redesign for such a small market.
On the mills I looked at several used Lagun mills in the 3-4K range, and also had used ones at a friends shop. Nice manual mills, but they wanted 3-4K, they all needed repairs and they not longer held spec. tolerances for production work (main reason they were being sold). With the used machine market you need to know what you are getting into, factor in repairs and cost of parts (if available). Many of the light industrial manual lathes have had heavy use in machine shops, so you may be inheriting a host of issues along with limited replacement parts. I dealt with another hobbyist that purchased a used Sharp 1340 lathe, and found out after the sale that the spindle was bent most likely because it had been crashed. Replacement from Sharp was more than he paid for the lathe, I tried to source parts for him through Acra because Sharp didn't want to deal with him because the machine was purchased second hand.
Sunmaster manual lathe production
