- Nov 20, 2018
- 710
I have had mine a couple years now. Dont know how I could live without one now. I improved my fences and clamp with replacements I made. Added an adjustable stop on the clamps so I can adjust to keep the jaws parallel if needed. Also built a small table that I can leave on permanently for vertical operation.
A machinist friend of mine gave me a tip on the blade angle adjustment. Clamp lightly with small vice grips two six inch metal rules on the blade standing straight up a distance apart. With a 90 degree triangle off the bed you can much more easily see if the blade is adjusted true. Such a simple tip that made an huge difference in my saw after I dialed it in. I had been trying to get it to cut straight with little luck before, and in less than 10 minutes it was better than it ever was. A better blade is helpful too. he recommended a 10-14 name brand.
