Harbor Freight air compressor repair
We got a tattoo once, could not see it though....
Ink costs extra...
Sent from my SM-G781V using Tapatalk
I’d probably give a repair a try first and be prepared to replace.
If you bugger it up, you’re no further ahead or behind.
I’d be tempted to try brazing instead of tig in a spot where “flatness” is so important.
You could drill and tap a hole through the center of the crack and install a set screw. Should be a pretty solid repair, just peen the threads to lock it in there.
Had a bolt come out of a valve on the compressor. Cracked the valve plate. Valve plate not available from Harbor Freight. Any ideas ? Tig weld the plate and machine the warp out. Make a new plate from a piece of aluminum plate. Replace the compressor with a whole new compressor? I know it’s Harbor freight, but surprisingly it has lasted from 2014.
I just purchased a set of Cast Iron Piston Rings from Aliexpress. Awaiting arrival, I wonder if you searched there if anything might come up for you? I will try to utilize them to repair my Saylor Beall Compressor.
