Ok , I'll play! For some reason, I keep thinking that they are called a "swing handle" Could be wrong and I bet I am, But I am going to try and find out right now.
They are "Indexing Handles" used where you can't turn the handle 360 degrees. Turn as far as you can, flip or index the handle and turn again. Repeat the process till they are tight. All titles are now the same, even the corrected one.
