I have been using a Milwaukee 5380-21 to dry drill 1 1/2" core holes in CMU / 4600 psi grouted walls, I run the drill in low ( 1500 ) speed hammer off. Every once in a while the core drill virbrates really bad when a slug pops loose and wedges inside the the core bit ( the core bits are 14 inches long ). I usually keep on the trigger and back the drill out to remove the fine powder cement dust and remove the core before going back in as it's too risky for me to try to core in one shot ( the cores are 8" deep ) and chance that it mighty get stuck. I use the short side extension handle that came with it and it helps when it does catch from time to time. It also helps if i am directly over the unit where i can make sure my arm can counter anything when it does catch to minimize torque spin. If the drill was a slower rpm ( like 850 ) it would take too long to drill out the holes and the torque would be scary if it did catch. The drill was never design to be a portable coring rig, but I managed to find 1/2 to 5/8" threaded adapters for the coring bits I am using, and I have always managed to make tools work in the capacity that they were never designed to be used for. If I was drill metal with the same bit , I would be using step bits to the size I need ( I have them to 1 1/4" ), the step bits work ok if the metal is 1/8" or less, never tried it on anything thicker, when they tend to catch I back off pressure on the bit, or stop the drill, switch to reverse, give it a tap in reverse, then switch back to forward. This tends to smooth out the lip a bit and remove any bur that will catch. I also use a bit of oil to cool the step bit a I drill.
- Al
