- Feb 1, 2018
- 1,868
The secret to scraping soft material like brass, bronze, Rulon /Turcite is a Biax 1/2 moon flaker blade ground at a neg 10 to 20 deg depending on the material. I discovered this technique years ago and have been telling my students like Ulma. The tip radius is 60 R as the bottom is also a 60 R.
If you do not have a Biax 1/2 moon blade, use a 1/2" wide carbide insert ground to a 20 radius and a neg 10 to 30 neg rake. You have to experiment on the material . The softer the more neg rake. Also when scraping the softer materials, use about 2 to 4 pounds pressure down. You can use a bathroom scale to measure it. Cast iron is about 8 pound pressure. You lay a thingpeice of plywood on the scale and hold the hand scraper on the wood like your going to scrape and press down.
