- May 7, 2023
- 1,332
My initial reply was in regards to squaring the business end of the reamer, now I understand you want to put a square for a tap wrench.The crankshaft passes through the right ctankcase half in a roller bearing. I made a 1.5 inch long bushing fitted into the crankcase bearing race bored to guide the reamer in the center. The end of the crankshaft that extends into the bolted on nose cone fits into a bushing in the nose cone and has to be in- line with the center of the bearing race in the crankcase. The fit on the nose cone bushing which is about 3/4" long is supposed to be 0.0005-0.0012 loose on the reduced diameter end of the crankshaft (0.5615 diameter) . The fit needs to be the length of the bushing since oil pressure is applied in the end of the bushing blind hole bore to feed the oil port in the end of the crankshaft. I'll try to incude a picture of the parts and the reaming set-up. Gotta learn how to do it first.
If the pilot bushing I have in the crankcase to guide the reamer in the centerline, would the chucking reamer wobble if used as a hand reamer? Is it because of the slow turning speed? Would it be better to chuck it into a hand drill?
If your bushing was reamed with the reamer you need for the bushing I would think hand reaming would be ok. If it was made otherwise it will likely wobble and be inconsistent in the way it cuts.
