yep!
so, is the reason a hand reamer cant be used in the lathe because of the long lead in
I have hand, machine, adjustable, single flute and then some oddball reamers. My most important and really my only concern when looking through my reamer inventory, is to find the size I need. Then I ream the hole with it. All the types work for me. Some not so great or have limitations, like the adjustable ones.
Running reamers by hand does not give a lot of power, but it does give a great deal of feel and finesse. For hand reaming, you want a light amount of stock remaining to be removed. The hand reamer taper will not even enter a small hole, and if it did, you would not be able to turn it as the cut progresses. The long taper makes the size grow gradually as the reamer advances. It is good for making the hole to size and round, but somewhat more difficult to make the hole go in the exact direction you want it to. That said, I have not tried using a tap follower with a hand reamer that has a center on the shank end, which might help a lot, come to think of it. For machine reaming, removing more material is not so difficult, and the hole can stay better lined up if you use a rigid spindle like a mill or a lathe to turn it. The work also goes more quickly under power, when time is money. chips&more's comments are worth reading again. With limited inventory tooling, often for a one off home shop job, we often want to do what we can with what we have. Where there is a will, there is usually a way.Great question.
I know Bob is correct. Or at least that is what the books say. But, why....
I'm commenting so that I get alerted when there is a response.
Daryl
MN
