- Jul 5, 2014
- 2,776
On my 55 I had to replace the horns and picked up a nice set from the local pick and pull. I got them mounted and wired up and they wouldn't work. I checked the horns before leaving the wrecking yard by jumping them on my car battery so I knew they were good
The horns have good 12v power to them. They are mounted right beside my transmission cooler fan. I tee'd into the ground wire of the fan and ran it to the engine block. I'm a really big fan of having a good ground so that's why I ran it to the block and not the core support.
At first I thought it was my horn relay that was bad so I replaced it. When I put the new relay in the horns kind of made a wimpy little sound and that was it. So I jumped the relay ground so it was on all the time and went to the front of the car and my trans cooler fan was on, but the ignition was off and the fan thermostat was not triggered. So I took the ground off the relay and it stopped. Jumped it again and the fan came back on, but was turning backward.
So I cut the horn ground wire at the t and the fan stopped. So I took a jumper wire and ran the horn ground directly to the engine block and the horns work., fan was still off.
The only thing I can figure is by sharing and teeing the ground with the fan somehow the power to the horns were diverted to the fan and the fan motor sucked up all the power from the horns somehow.
Am I right on this?
Am I right on this?
