Do you know where that would be? all I know is that it was made after 1918Have you found a serial number on it? If you do I can give you a year of manufacture.
that would be a convenient place but you see mine does not really have a vertical way more of a slot. ill go take a look when I get a chanceOn mine it is at the top of the right vertical way.
John is just cheap. That shaper will clean up with a lot of elbow grease. I say if you can get it for less than $500, you can’t lose.That machine likely dates to the 1920s, it could likely made to run well, with a whole lot of cleanup, I'd offer no more than $200.
I wouldn't grease the ways, I already have gone through the pain of that cleaning my Bridgeport and it came out of an actual machine shop.Please, don't just put grease on the 'loud parts'! Find out what the proper lubricant is and use it. Using grease can trap chips and cause scoring and wearing in the ways. There may be a few places where grease is the lubricant of choice, but most moving parts on shapers will use some grade of oil.
