- Mar 25, 2013
- 4,630
Earlier in the thread I was asking about having all the broaches the same length so that you could use the fixed 1 deg angle and not have to adjust the offset if you change broaches. The issue I ran into was grinding all the broaches to the correct OD without adjusting the length. In the end, I ground the broaches slightly oversize and then sharpened them (shortening them) to get the OD correct. That resulted in all my broaches being different lengths. Using a surface grinder may obviate this issue for you . Just some food for thought.
Robert
Robert
