- Mar 25, 2013
- 4,626
Jeff- I am finishing up some of the gear shifts and I want to run something by you. I was considering increasing the offset of the eccentric part from .090 to .125 or so. I am concerned that if the gear teeth are not cut deep enough it may not be possible to disengage the worm. This would give us more room. Also, once these eccentrics are cut you can't really change them. I just want to make sure you think this is a good idea and will not interfere with something else.
