It does have a speed control but the highest speed is not very fastYou could probably feed it a higher voltage (it's a dc motor I think) from an external source but that's a bit more than just a mod I guess.
Plus it might shorten the life of the motor somewhat. Doesn't that model have a speed control?
-Mark
Just compared to a bridgeport it is much slower. Just slow for what I need it for. Glad it works for you.I don't have an answer for you but I'm curious to know what you consider slow. mine is ~1/2" per second on high setting and I find it decent speed for a small power feed.
Any chance you have a video of yours at the highest speed? Just wonder if mine is slower than most. ThanksI don't have an answer for you but I'm curious to know what you consider slow. mine is ~1/2" per second on high setting and I find it decent speed for a small power feed.
I don't have a video.Any chance you have a video of yours at the highest speed? Just wonder if mine is slower than most. Thanks
good idea - thanksOK. even if you were to bypass the speed control you might only gain another 10%, so nothing you can do easily to get a large increase I think.
Why not build your own? That would be a fun project
One of the older Makita 9.6 volt drills would be a great starting point- they had a selectable High/Low gearbox
and lots of torque
