- Jan 20, 2016
- 173
I have owned this lathe for about 6 years now, and think the PO may have it about same time. I can't actually find a serial number to know the year/age. I really do like the machine for the most part.
Was taking some roughing cuts today to hog down some 3" dia HRS stock to 2.5 dia as part of initial steps to make a bushing for the new Norton 3X bench grinder wheel (2.5 flange OD, .500 ID, 1.000 OD). Lathe was running perfectly normal. Thought my roughing was about at .030 over (where I wanted to be for the roughing cut), so stopped motor and measured the dia (correct). Set the dial indicator to measure the shoulder area, dialed it the compound to start roughing the 1.00 dia portion. The lather motor would not start with the selector switch lever, something just made a loud humming sound.
Turned off the power, unplugged it from the wall, plugged it back in, open the safety stop, powered the green button up, and tried to start the motor again. Nothing but hum. Tried forward, reverse, and even tried to help turn the chuck to ease the motor start load. Just hums. Finally held the start lever on and spun the chuck, which did make the spindle rum about 10ish rpm (I was running 600 rpm before) while humming. Lathe is against wall, so it took some effort to clear out under the base and get it slid out enough so I could squeeze behind it.
This is the inside of the control cabinet, the motor with what looks to be perhaps both start and run capacitors (?), and the motor tag.
Any idea of where to start checking/troubleshooting this setup? I can't reach the spindle rotation start lever and get to motor quickly to feel if that is source of the hum, but thinking the motor is the hum source. In order to be sure, I would have to keep it humming for about 1 minute to get from front start lever to back motor, feel the motor, and get back to the lever again to shut it off. Would that hurt anything further if it is actually the motor or capacitors?
Would the 150uf and 20 uf on the motor tag be the capacitor ratings? Any easy way to test them?
While I do my own wiring and electrical installations, I am buy no means an electrical guru.
Thanks for any suggestions,
Ted
Ted
