- Sep 28, 2013
- 4,309
to be honest so far I've been pretty impressed - the nod was out by a touch, so I sorted that out with a piece of 7-up can between the knuckle and the base, which put it within 0.01mm over the width of the table. All the sliding surfaces are in good condition, no gouges or ugly machining marks, just the usual Chinese way cutter marks on the flats. Backlash is minimal and there's little (0.01mm or so) movement in any of the axes between locked and unlocked. The gibs are different on mine though - they're adjustable from the ends, not the sides, if that makes any difference. I guess it's just the luck of the draw.
