I finally got my 6x12 Walker magnetic chuck ground and I have some used 1"x2"x8" magnetic parallels I would like to clean up. I have checked them and they are all fairly the same size (within .004") in height and width. I would like to clean them up an make sure they are the same thickness and height by grinding them on my Harig 6x12 grinder. I am currently using a Norton 46J grit 6"X1" wheel. Because they are steel plugs in an aluminum block I have some concerns grinding the aluminum. Is this possible and if so what concerns should I take?
Thanks
Skipd1
Thanks
Skipd1
