I can't find any information by the part number. I would think that any shank that would fit the socket would work. You would have to have a good fit to keep it from wobbling in use. I've never see one that attaches with 2 set screws like that. Looks like it might take round inserts.
There was a couple more in the box. All made by Mil-tec. Can't find anything on their site. One is a button head cutter the other is a shell mill arbor. All have the same mounting as the one in my first post.
I think it is an obsolete part number. The FC-2-3 they have now is a bit different. So it may have been made for one of their priority shanks. But an email to them might shed some light on what that shank would look like.
they are just small special facing mill cutters with round or triangular carbide inserts---you don't have to have the factory made shank---if the IDs are all the same---just make your own shaft to a snug tolerance and mill two flats for the set screws----and use them in your mill collet-------I have a hand full of similar new ones to do the same-----Dave
I would just make an arbor Turn to a snug fit with a shoulder , take the setscrews out. Push the cutter on the arbor and use a drill that just clears the threads and demple the arbor. It will take much more torque that way. I wouldn't mind haveing something like the ones with round inserts.
