- Sep 1, 2020
- 1,593
Got a 1983 Honda atc200e for $180 from my friend, supposedly needed a new coil but I cleaned the points and got a spark, ran first pull but the whole choke assembly was missing and the carb is very corroded
Cons:
Rear left tire has a leaky stem
Carb is toast
Air filter is gone
Headlight doesn’t get power but the stator works
Needs battery
Choke cable housing is snapped
Missing read brake lever
Rear brakes don’t work/ need pads
Shock is toast
Shifter striped the spline and needs replaced or welded
Need a new seat cover
Pros:
Plastics are in great shape
Almost me rust or damage
New front tire
Back tires are halfway good
Throttle cable is very smooth
Started first pull and under a second in electric start (not anymore)
Now time for pictures
Cons:
Carb is toast
Air filter is gone
Needs battery
Shock is toast
Pros:
New front tire
