I would like to find out the foot print details of a 9J. Hole spacing and size of the base is the info I need. I'm working up a set of skates, and hope to get it home before Labor Day.
I don't know the dimensions you are seeking but I did get a set of machinery skates from northern tool that work well and they are cheaper than I could buy the ball bearings and make my own. If you go that route you should definitely also cut some 2x4's down to cushion your machine from the skate and reduce the chance of it slipping off the skates - or figure out a way to anchor the machine to the skates.
