- Nov 26, 2012
- 1,307
Push the wheel hub out of the bearing assembly and you have a good sized flange to work with.What specifically would I look for with the front wheel hub assemblies?
Pics are front and back of one next to an assembled one from a 1 ton truck. I was making a grinder hub out of it.
HSS did fine cutting on the splined area. I thought it would be to hard but not bad. I threaded the opposite end for the puller thread.
These assemblies with the bearing have a cogged wheel in them that the wheel speed sensor reads off of. They look interesting to build an indexing head out of. Could be horizontal or vertical. And use the gaps in the senser wheel for an indexing pin.
