- Jul 14, 2017
- 2,451
I left this car to settle on the jack stands for a few days it was more because my health started to act up but today i finally was able to go in the big cold garage and scan the 607 for fault codes, there was 9 in the memory most of them repeating. Main two are EGR blocked and becomes is french it has to be two of them, and a map sensor, i quickly located it on the engine and inspected it and it was gunked up with junk from the egr, i looked at the number and happend to have a spare from a hitachi digger engine i have laying around i swapped it clear the codes and only the EGR code come back after running it a bit. A bit more inspecting sowed the huge oil leak is coming from the middle of the V on the engine, where the Oil cooler and filter housing is located so maybe my problem lays there.
