- Jun 12, 2014
- 4,826
I started with a mill, for me it did more of what I needed, and had never used a lathe so didn't know what I was missing. At this point, in particular with what you want to do, you might as well get both because sooner than later you will kick your self if for not getting the other. If you want to make parts, then it is a no brainer, you need both. I agree with 7milesup, the PM1340GT or 1440GT gives you enough capacity and accuracy for turning w/o getting into the heavier/bigger lathes. They are very good quality machines if you can get into this price level. Buy once, cry once. A lot of gunsmiths and tinkers go with these lathes, the 1440GT has the larger 2" spindle bore and manual foot brake which are nice, but the 1340GT is also very capable. Go 3 phase on the lathe, motor control and surface finish is better. Do a basic VFD control or go RPC. I also agree that the PM-833 is a very capable mill, if you are not boring large holes go with the variable speed 833TV. If you get the CNC itch down the line, there are conversion kits and lots of information for this model. Space wise, as far as machine foot prints, it is a good combination. If you want to go hog wild on the mill than I would move up to a full size knee mill like a PM-949 or KTM-3VSF, but at big price hike. Mass = rigidity, but not necessarily quality. Taiwanese machines offer better quality at a 20-25% cost premium. Used mills and lathes, may not be much savings these days, and more likely to bite you if you do not know how to fully assess their condition. New machines have a warranty, PM/QMT seems to have the longest (5 years on Taiwanese machines) and a good reputation.
I will add one more must have machine to your pile, which is a metal band saw, w/o that how are you going to rough cut all your metal. Consider a PM-712G Horizontal/Vertical or Jet HVBS-710SG 7 x 10.5 Miter Band Saw to holiday buying spree. I have the Enco/MSC version 712G and it works decently, but if I were to do it again I would go with the Jet Swivel head which is much better for doing miters and such. Jet is running a year end rebate until the end of the year, so this model will come in at just over 2K delivered with the rebate. Mine has coolant, if I do a lot of cutting I use it, if infrequent I run dry with a good blade and manually apply some cutting oil for steel.
Welder, it is an art to get it into it and do decent welds. I don't weld but have friends that do and have spent years perfecting their skills. TIG is harder than MIG, lots of parts to the puzzle. The Miller Multimatic's get very good reviews as a combination welder and they seem to hold-up well. Plan on 2-3K as an entry level, I would put this 2nd tier to the machines above. If you have friends that weld, spend some time with them, have them weld up you parts and learn the basics first.
Prices continue to go up, this year it seems like everything has gone up 15-20%. Do not know if this is tariffs, limited supply, or global costs but I doubt anything is going to be less expensive next year. Supply and inventory is going to be significant issue probably until mid to end of next year. Ok, you have the most of the machinery list, now for the bad news. Outfitting the mill with a decent Vise like a Kurt DX6, collets, parallels, end mills/face mills, indicators and such will very quickly push you past another 1K. On the lathe, well that is a sink hole money pit when it comes to outfitting it with decent tooling. I have spent as much on chucks and tooling as I did for my lathe. You can start out light, but I would realistically start out with a 1-2K budget for tooling, and that assumes you already have decent chucks.
