Georgii Kobold Motor Parts
Scra99tch
H-M Platinum Supporter
Dec 2, 2016
238
Guess the company is still in business. But I am looking for a lack of a better term contactor for a motor that had two position speed control. This came off a 1968 fortuna Grinder.
Okay found a part number for something a little more modern.
Siemens 3SE5 250-0KC05
The current ratings though are not the same the one I am looking at is 400V 6A, not the 500V 10A on this one. Is it just built better today then in 1968 that its resistance is not as high?
Am I safe to say that would work, its powered a 1/2 HP motor switching the speeds from what I gather.
If it is the same physical size and function it may be your only choice, even though it probably won't last as long as the original
I assume it mounts inside the motor? Otherwise could you put an external contactor or relay? You would have many more choices as far as ratings
-Mark
Will you be running this off a VFD? I doubt you have 380v / 50hz three phase in New Hampshire. I would figure out how to power it before putting anything into repair. If it's a standard frame motor you may be better off replacing it.
John
All four motors can be rewired to 220v 3 PH.
I believe it was originally 220V
This is something I will have to read up on as far as sizing heaters and rewiring the motors.
John
Wont run off VFD just a rotary phase converter.
