- Apr 23, 2018
- 6,556
AFAIK Gearwrench dies are carbon steel, not HSS, same as most of the Irwin I've encountered. Irwin at least makes HSS taps and dies, but as i recall they cost 3-5x as much.
Sent from my Pixel 7 Pro using Tapatalk
I suppose my set is older, I bought mine around 2014 when the tap and die sets were introduced. It's definitely not carbon steel, the permanently bright finish shows the metal is high in moly and chrome. That's not to say they didn't cheap out later in the run. I'd say the GW branded taps are very good as far as import consumer grade stuff goes, but a side by side comparison with any random tap from GTD or Cleveland makes my hair stand on end. The GW taps are on dimension and do cut, so that's a win. I also have both sets of Irwin tap, die, and drill sets, they are TiN coated HSS (or TiN colored coating more likely) but are pretty good, but they're from Y2k, so they may as well have belonged to gran'pa, because they don't make them like that anymore at the big box store level of quality.
