- May 26, 2013
- 90
Okay... I have owned an Australian Hercus 9A (copy of a Southbend) lathe for maybe twenty years now.
At first, it only ever got a little rudimentary use, but as time has passed, it plays a larger role in my work.
Great little lathe, and when I bought it all those years ago, it came with every conceivable Hercus accessory you would ever need, including a STACK of change gears.
Now, here's the thing... I am wanting to learn threading, and I have ALL of the equipment, and a little knowledge, so it should be fun, but... I am still not sure if the gear train I am running (which I have NEVER changed), is in actual fact, the set factory correct gear train.
I have spoken to Hercus here in Adelaide, South Australia, but they are of no help, and don't really want to help.
I have scoured the net, and believe I have found what is purported to be the STANDARD gear train for the Southbend, which is as follows...
The typical set-up for the quick-change gearbox is
20 tooth stud gear,
80 tooth idler gear,
56 tooth gear on the input shaft of the gearbox,
40 tooth stud gear used for very course threads
(This gear is used in place of the 20 tooth gear and stored as a spacer on the input shaft of the gearbox when not in use).
This makes sense, sort of, but WHY, do I have all of these OTHER gears, as well as a 127 tooth for metric?
Can someone perhaps demystify the correct FACTORY set-up, for the imperial lathe I have, as well as somehow, explaining to me WHICH gears I need to change, to cut metric threads, and how?
Even a picture would help.
I have the second edition copy of the Hercus manual, but it doesn't really elaborate that much I'm afraid...
I think I'm missing something here, or over analysing.
Cheers
Ian
20 tooth stud gear,
Cheers
Ian
