My main lathe is a Chinese SC4, which for the most part is excellent for what I do with it. It has a belt from the motor, but is gear driven just before the spindle.
I have observed a faint radial pattern on workpieces after careful facing, that appears to be a 'print' of the last gear before the spindle. I can count the number of radial 'sectors' and it does match the gear tooth count of the last gear, so it seems to be the case, but I am interested if anyone else has observed this on their gear driven lathes after careful facing cuts. More particularly, if they have seen it on belt driven lathes after the same cut.
If I am correct about the last gear printing on the facing cut, then it certainly is a negative of a gear driven lathe. The pattern is very faint, only a micron or two deep, but it is a bit of a pest when polishing/finishing. The irony is that if the lathe did not have such a superbly smooth cross slide power feed, I probably would not be able to see it!
Am I correct in thinking that one of the most desirable attributes of the Harding HLV is the belt drive, combined with the electric motor power feeds? (Amongst its many other fine qualities!)
I also have a belt driven 9x20, and it shows no such pattern, but then it has no power cross feed either, so it is difficult to achieve as clear a facing finish as my SC4, so it may be there, but masked.
love to hear of others observations.
Cheers
Cheers
