- Feb 7, 2013
- 2,495
I now have three boards on the work bench, the nonfunctional one(O) that was originally in the opener, the one I call "A"
because it shows a little activity, and "B" which does nothing at all. The circuit diagram I have isn't a complete diagram
since there are parts on the board not indicated on the circuit for some reason. There is a voltage regulator (78L08)
on the boards so I did a little testing on A and B to measure the output voltage while the boards are plugged into the
opener. Interestingly B has the proper 8 volt output but A reads 3 volts. Board O sits off to the side at the moment
because it shows a short on one of the pins on the main chip so considering it as a parts board presently. I have some
regulators(78L08) ordered so will put one in A and see what happens when they arrive. A complete circuit would be
quite helpful but so far have not come up with one. Of course voltage testing on the components would be a big help too
but will have to pull the opener off the ceiling as it is not practical with it overhead standing on a ladder. As a side note,
I wonder if any of you remember "Sam's Photofacts", a publication by Howard W. Sams from before the age of
computers. I did check there but found no reference to Stanley openers so it was mostly for radio and TV stuff.
