- Jan 4, 2021
- 1,898
Had that happen on a fabricated SS part for a BioChem project (on the day that we had a Big Wig tour coming in). The department machinist who made the part was off that day, so took it to the main machine shop: they were able to get the relatively cause threaded pieces apart using a six-jaw and 3-jaw of the two ends to apply torque with final surface finish damage, then relieved the external threads (single-pointed) and advised a light coating of pharmaceutical-grade anti-sieze. Didn't have any issues after this.I whipped up a machinist jack the other day. I used a piece of stainless steel that I had laying around, it machines beautifully.
It came out great except it felt like there was some grit in the bore.
I placed both pieces in my ultra sonic cleaner.
When it was finished I screwed the pieces together. It got tighter and tighter. Maybe because the pieces expanded in the heat?
Now it’s ruined. I can’t budge it. It’s completely stuck. Scrap pile!!
I used a commercial tap and die to produce the threads.
What the heck happened??
Have you ever experienced this??
Don’t laugh at my knurling
Couldn't use anything other than SS in the part due to the application, and it took the better part of a week to make it so it was a good thing they got it apart.
