Hi, I bought a used G4000 Grizzly. When started to get the feeds and threading working I ran into an issue with the leadscrew where it binds particularly when the carriage is run over to the left near the headstock. I took off the leadscrew and apron. Cleaned the chips out of both, partially straightened the leadscrew and reassembled, by eye it still has a .030" whip in it. When I tighten the apron to the carriage things bind up, to where you can't turn the leadscrew by hand. With the carriage in the middle it loosens up and it is real nice towards the right end of the travel. I'm planning to make some shims, from .012" brass to put between the apron and carriage. Has anyone else run into issues like this, anything to check that i may be missing? I'd really like to avoid messing with the mounting of the ways and headstock, it faces good and the cuts across the work are straight enough for the projects I'm planning. I haven't unbolted the gearbox yet to see if i can raise the left end of the leadscrew a bit by messing with it's mounting position.
