- Dec 18, 2019
- 6,464
So just drilling out a piece of 12L14 with a 3/8" drill. Was going to make a boring bar bushing. Thought I'd put a 3/8" hole through, then put the tube in the boring bar holder to accurately line it up with the spindle. Then drill to "size" and ream. That was the plan anyways.
Seemed a little harder than usual to advance the quill. Was clearing chips every so often. Near the end of the hole, (at 2" extension) all of a sudden, the drill chuck, quill and handle started rotating as one assembly! Took a moment to process this and decide this wasn't good. More like a moment of astonishment, then realized I had to do something. Stopped the lathe. Loosened the drill chuck and backed off the tailstock. Handle is stiff to move - doesn't want to move. Removed the tailstock and put it on the bench. Using an old drill chuck, extracted the drill from the workpiece. It wasn't hard to remove.
From the parts breakdown, I think if I take off the handle, I might be able to drive out the leadscrew and quill from the handle side out the quill side. Not looking forward to viewing the carnage. Maybe the set screw pin sheared under load. Anyone have tips for disassembly? Gee, was having fun in the shop, until that bit of excitement!
