- Feb 2, 2013
- 3,645
i worked on the retainer yesterday and finished.
here is what i did to get there...
after rendering the cast iron slug from the saw
i center drilled and through drilled it to 5.5mm and reamed it to 6mm.
i set it up on a drilled and tapped M6x1.0 mild steel pedestal
i turned it eventually to concentric with the center bore, i took .010" cuts with HSS grind with a generous radius.
there was some interrupted cuts for about the the first .030",
then it started turning concentric and i took a couple skim cuts to ensure i was good.
i then went to facing the retainer
i hit a hard spot and had to switch to carbide after dulling the HSS a couple times at .010" DOC
i attacked a bit more aggressively with the carbide, and it straightened the problem right out
and here is the turned retainer!
the grinding wheel is a Cup Wheel- 8" in diameter X 4" Deep X 3/4" thick
1740 RPM grinding speed
i mounted the wheel today and took it for a test run.
less than .002" runout as indicated on the spindle on a 40+ year old grinder
i'll say it was a successful job
as always thanks for reading!
