- Feb 2, 2013
- 3,628
My son has said that he has outgrown his (twin sized) race car bed, and wished for a big boy bed.
after looking on Amazon for mattresses , i decided to construct the bed frame.
i saw a bunch of bed frames in the search, but they all looked cheesy and cheap.
so i did the next best thing, i spent $200 on lumber and $30 on fasteners and $15 on stain.
the bed frame is solid and sturdy and could easily support 450 lbs.
Being a complete hack,
i disregarded all proper carpentry techniques and went rogue,
but somehow the bed frame still looks decent
here is how i went about it...
i planed all the boards to thickness, to reduce the sanding time- they turned out great!
i cut the 4x4's to 18" and beveled one end 20° to 3/4" deep to prevent chipout of the support leg
i cut the 75" pieces of 1x6 for the sides (and 1 1x4x75 for the central support)
i cut the 55" pieces of 1x6 for the ends
i cut the 55" pieces of 1x4 for the slats
i laid out the bolt positions on the 1x6's and the 4x4's and drilled to 5/16"
i added the sides and ends to the 4x4's and rattled them up after getting all the bolts installed
i added the center support and got it to the right height, and supported
i started laying out the slat location and used spacers to keep distances-
maybe you can see the slight change in gap, i used more gap at the foot end, less gap at the top - {maybe i overthought this part }
i started stapling the slats in, one by one until the top was complete.
i ended by screwing top boards into legs where possible
i sanded the works (shabbily, i may add) and sanded it again to 150 grit
i went over it again with scotch brite pads and then again with microfiber cloths
i didn't think to take pictures until i had the wretch assembled and started the staining process.
i made a stain application bonnet from purchased cotton painting rags, rolled up and tied off - kinda like a pitchers rosin bag.
i shook the crud out of the stain and got the bonnet wet and started rubbing for a couple hours, flipping the unit around when necessary.
so without further delay, here is the pictures...
it looked like it was finger painted, so i went over it one more time...
i think it turned out solid, but a bit blotchy in places.
all in all not to bad
Material List-
FULL SIZE BED ONLY!!!!! 54" x 75"
10 1x4x10"- (cut 20 @55")- these are the slats
1 4x4x8' (cut 4 @ 20" {Nominal} lengths- [i cut mine @ 18"]
3 1x6x8' (cut 3 @ 75") - these are the 2 sides, and one center support (you could substitute a 1x4x75" piece here- I did )
1 1x6x10' (cut 2 @ 55") - these are the end boards
1 1x2x10' (cut 2 @ 55") these are for the cleats on the top of the slats-(to prevent Y axis movement of the bed beyond the slats )
16 5/16 carriage bolts - (i had to use hex headed bolts ,as box depot was out of 5/16 carriage bolts)
16 5/16 hex nut
16 5/16 lock washer
16 5/16 flatwasher
150(est) 18Ga 1-1/2 crown staples
(approx 12 # 8 wood screw)
I used a Cherry stain that is surprisingly similar in color to my sons bedroom furniture
other hardware used on my build-i used a 1x4x75 for the central support.
i made a simple support from scrap and screwed through the end cap , on both ends-
then added screws into the center support vertically, to limit twist.
thanks for reading!
Material List-
16 5/16 hex nut
16 5/16 lock washer
16 5/16 flatwasher
thanks for reading!
