WD40 has no real lube value, maybe kerosene is no better. Pierre
pdentrem Active User H-M Supporter Gold Member Joined Jan 28, 2011 Messages 3,496 Apr 5, 2021 #11 WD40 has no real lube value, maybe kerosene is no better. Pierre
J john grinder Registered Registered Joined Dec 17, 2016 Messages 37 Apr 5, 2021 #12 danallen said: I am running premixed 50-1 Trufuel from Tractor Supply with good results. Click to expand... What type of engine are you using it in ? pdentrem said: WD40 has no real lube value, maybe kerosene is no better. Pierre Click to expand... pdentrem said: WD40 has no real lube value, maybe kerosene is no better. Pierre Click to expand... wd-40 was invented by NASA to dry electronics.
S sdelivery H-M Supporter - Gold Member H-M Supporter Gold Member Joined Nov 14, 2020 Messages 1,768 Apr 5, 2021 #13 WD= water displacement....read label, No Lubricant
D danallen Registered Registered Joined Dec 12, 2020 Messages 20 Apr 5, 2021 #14 john grinder said: What type of engine are you using it in ? A Farm Boy. Click to expand...
