- Mar 22, 2013
- 215
Gentlemen,
The engine is running. Having been away for almost 5 weeks I was in a rush to get it running for the NAMES show but that didn't happen. My apologies to those fellows that came to the show to see it running. This is the second running. I fired it up earlier in the week but had a few adjustment and modifications to make.
It seems like the air bleed hole in the carb needs to be a little bigger because it takes too much adjustment on the main needle to go from idle to high speed.
So far everything seems to be working well. It looks like it will need a different seal in the timing cover because it leaks a little.
Here's the link to the Youtube video.
http://youtu.be/tdrEHY3uqqs
gbritnell
gbritnell
