- Jan 7, 2016
- 3,278
There are so many variables and possibilities to make this work better.
A .20mm might help quite a bit for example. Slowing the print speed down, along with cooling, can make a difference.
As you mentioned, filament can make a big difference, but trying to sort that all out is maddening. Once you change filaments, one should do new calibration tests, including pressure advance. This can even change with the same filament but in a different color. I am still on the quest to find a good filament and stick with it.
It does look like you have a win for the most part. Congrats.
