- Dec 18, 2019
- 6,597
As you can tell from the thread title, this is a rant.
Bring in my 2015 for safety inspection. Get called that they failed my driver side headlight, for being too cloudy. Offer to sell me a "fix" for $150. I say, no thanks, bet I could fix it myself. Didn't want to ask how long the treatment was guaranteed for. Then I asked, how will I know if my work is good enough? What is the criteria for a pass? What is not too cloudy? Finally coax out the explanation, it has to be at least as good as the passenger side, which did pass. Ok. Guess I won't touch the passenger headlight at all, since it is my reference.
Get the rejected car back. The driver headlight is pretty cloudy. Honestly, it looked dirty. Wash it with some windshield wiper fluid, it showed clear when wiped, but then clouded over. I've seen that before and know the fix. Started the search in the garage for a bottle of Meguiar's Mirror Glaze Professional. It is basically a water based polish. Takes me 3 minutes to find it. A couple of minutes to shake it up again, as the old bottle has settled. 2 minutes after that, and 2 paper towel sheets later, the headlight looks almost new. That old bottle of Meguiar's cost well under $10 when I bought it. Pretty sure any gentle car polish would work. No UV protectant, so I will need to do it again in a few months, or at least before the next inspection. One of these days I will find some UV protectant, that isn't ridiculously overpriced, which should reduce the time between polish jobs.
I don't know, but, failing for the sake of a 2 minute polish job is bad, and making the push for the cleaning and protecting of the headlight for $150 left a bad taste in my mouth. Especially since the amount of work to clear the headlight takes so little time and effort. Makes me feel like they wanted to take advantage of me.
I will bring in the car for a "re-test" tomorrow. Don't think I will be going back to this place for inspections (which are yearly in NH). The place used to be ok, but has gone downhill in the past couple of years...
Rant over.
Rant over.
