- Feb 28, 2019
- 502
So oil quenching a round shaft without much detail wrapped in foil would probably work ok.
I believe I've heard this referred to as the "the mantle effect", where immediately following the plunge the part is surrounded by a mantle or "aura" if you like of super-heated liquid and gasses. For the most part we try to avoid it but I've run across situations where it was actually desired as a way of mitigating the initial shock from immersion. ie: let the mantle exist for a few seconds, then agitate the part to reintroduce it to the un-heated quench liquid as a kind of two-stage cooling process.Most descriptions of oil quenching describe how to move a part around in a figure eight or some other way to provide constant new cool oil contact.
agreed, RJ!I would expect that it would be more about a thin layer of air preventing efficient heat transfer. If the foil made close contact with the part, no problem but any trapped air would prolong the cooling process decreasing the ultimate hardness in that location.
