- Mar 26, 2018
- 8,413
Hello,
I purchased this old Bridgeport several months ago.
When I went to see it before I bought it I was frustrated with an OCC error code. Not knowing anything about it I just reset it, it seemed to work after that.
I got it home and I find I have this intermittent issue as I had before.
In the "FM50" manual, OCC is"over current at steady speed".
According to the manual, the possible cause is;
1. Transient change in load
2. Transient change in power supply
Countermeasure;
1. Examine the loading configuration
2. Install inductor on power supply side
As I look at the pic, I see a ground wire going nowhere. Maybe I should provide a proper ground?
I hooked it up exactly as the previous owner had it. Hmmmmm.
Anyone else have one of these?
Any related wisdom to share?
Countermeasure;
