- Nov 28, 2013
- 197
I was not impressed by the little screw used to index the thread cutting drive gear to the spindle. There is a small hole in the spindle and you drive this small screw into it which then occupies a notch in the drive gear for the threading attachment. It is certainly simple and it does work, but there is a problem.
The end of the screw protrudes into the bore of the spindle enough to block the tube I'd hoped to cut. I have a Proxxon stone-burr which is long enough to reach the protrusion and grind it flush with the inside of the spindle. Doubtless I'd also grind a bit of the spindle itself out of basic clumsiness. Does anyone see anything wrong with this scheme?
It doesn't look like anything else among the hundreds of Sherline attachments depends on the quality of that end of the bore. Is that correct?
If you don't like this idea, what would you do? I'm not in Wisconsin, but I like the idea of a small Cheesehead screw for this job. a lot more than what Sherline provided. and inserted in a proper drilled and tapped hole.
