- Mar 27, 2022
- 425
So I had been noticing that when setting tools to the tail stock they were miles from center at the headstock. Also the compound would get tight or loose when rotating.
I confirmed with a level that rotating the compound changes the pitch. Taking it apart I found that it’s been repaired. The repaired side is about .011” low.
What would be recommended for repair? I was thinking fly cut it down till flush and clean?
Would I indicate it in off the non damaged parts?
