- Jan 26, 2015
- 1,939
You might find that seal by just looking for one with the same dimensions or maybe one that is same OD & ID but thickness is just a bit smaller. As far as gears you might also find one that is the same except for the bore. Then you can either sleeve it or bore it out depending on what is needed to fit. I do this all the time when trying to fix old stuff. I have had to make spacers for old bearings that are no longer made. Bought gears and bored them out and even had to face off shoulders to make them fit. Almost all the time I do the job cheaper than if I bought original parts and with readily availbable stuff.
