- Sep 28, 2013
- 4,319
starting out I'd recommend getting a set of cheap SCLCR boring bars (8-12mm), a pack of CCMT and a pack of CCGT inserts and run with that (about $50). Then as you figure out what sizes you use/ need the most, replace as necessary with solid carbide indexable boring bars (about $30-40). You can use the same inserts with turning tools, which keeps things simple.
The above is what I did about 5 years ago or so and I've been very happy with the results on an Atlas 618 lathe. I'll be passing on some of the spares when I sell it and using the rest on my SB9 when it's up and running.
