Hey guys I have been teaching myself bench work for quite a long time and it came to my realization that I wasn't able to file a metal block square i could get one surface flat but I can't make all of them 90 degrees to each other.Any tips
Oh how's Mr hustlers btw and I didn't know gunsmith apprentice has to learn benchworkI was told by a young apprentice at Colonial Williamsburg Gunsmith shop that that use to be an exercise that apprentices were tasked with. File by hand a 1" square block, all sides square and 1" in measure.
You got it right i might be over compesatingHere's a little trick that I use that may help you. Cover the surface that you are going to file with a magic marker or similar. I usual use blue or red, doesn't matter. Take a square so that you can see the high area. Take a couple of strokes with your file, then check again with a square. I suspect that your problem is that you are over compensating. This should help and with practice, I'll think you will do fine. I started doing this when I got bifocals.
What do you mean.That practice must have started when Apprentices weren't paid by the hour.
What do you mean?
