- Nov 23, 2014
- 2,606
I have one of the Eastwood 8" bench shears (mine is from Woodward Fab - same machine) and it works very well. What sold me was shaving 1/16" off 16 gauge steel without leaving a burr. It can cut a radii if you're very careful, but best to take multiple swipes. They demo'd a throatless shear (Beverly style) went I visited Woodward Fab that worked great also. That one is better for free-forming shapes.
I also use a Woodward Fab (other generics out there) 4-ton 6" notcher which does a 90 deg. cut. I use it for shearing stock in addition to notching, is rated at a 6" cut in 16-gauge CRS.
Also use aviator snips, Adel sheet metal nibbler and some Tiawanese equivalents. Use some Malco 30 deg. notchers too. Have a Campbell Hausfeld air nibbler that makes a huge mess spitting out ~1/8" crescents of whatever you're cutting, but a very nice job.
For sheet stock I use a Tennsmith 37" wide stomp shear. It groans a bit if I'm cutting a 2' long piece of 16-gauge, but it'll do it. Biggest problem is my weight; I'm between 165 - 170 and don't get as much on the pedal with a hop as a 200 pounder!
I have one of the HF 3-in-one 30" machines and would recommend not trying to shear 16-gauge on it. 18 gauge would be a real challenge also. On the plus side, in the shear model the eccentric cranks/links on the sides are in compression so you might be successful, but you'll probably flex something and bend the metal instead of shearing it. I tried the press brake on a 16-gauge piece of stock 12" wide and broke the casting on one of the side cranks/links (shaped like a comma). In the brake model, the side links are in tension and put a lot of strain on the attaching area to the moving shear bar/brake. Maybe they've beefed them up, but if they rate the machine at 20-gauge CRS at 30", I'd probably only go 22-gauge.
Of course for crude cutting there's always a plasma cutter or stick welder. I've rough cut sheet metal with an 1/8" rod in a buzz box at 120 A, just obliterates the sheet metal at the stick; purposeful burn through. Then grind/sand the edge to a line.
Bruce
Bruce
